Shelly 1 auto reboot problem in v1.11.8
  • Hello,
    I've still reboot problem in 2 out of 20 my shelly 1s. FW is latest everywhere. WiFi coverage is very good.
    It happens 1/3 times right after switch on command from HA.
    The log contains:
    2712973427 json.c:426 RAM: 50864 total, 36400 free
    2725536115 json.c:426 RAM: 50864 total, 36580 free
    2727546757 mgos_http_server.c:180 0x3fff222c HTTP connection from 192.168.1.39:36838
    2727555596 switch1.c:394 Relay on pin 4 changed state 0 to 1
    2727562357 cannot emulate flash mem instr at pc = 0x401a5ac0
    any suggestions?
    br,
    arek
  • Hi and welcome to the forum. :)
    Do the reboots also happen if you turn off HA and switch via hhtp or sw or app?
  • Hi!,
    No, I'd never seen reboot after switching off...
    Switch is practically never used because shelly motion is a trigger for turning on/off (via HA + NR)...sometimes somebody who does not leave at house use switch for turning off and it is working correctly. To be honest same configuration shelly1+motion I have in 6 places and only this one has an issue.
    Switching on from HA interface manually via interface has same results ~ 1/3 actions causes reboot.
    In HA I use official shelly integration.
  • Unfortunately, I'm out of HA.
    My gut feeling:
    Either an error in the HA connection or an inductive launch triggers the reboot
  • Dieses Thema enthält 25 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
