Shelly TRV and Shelly Motion firmware update 2.1.6 is released
  • Shelly TRV and Shelly Motion firmware update 2.1.6 is released
    Change log:
    - Newest WLAN driver installed with better consumption optimisation
    - Bootloader fix which freezes the device after OTA or reboot
    Shelly Motion:
    - LUX reported separately (dark/twilight/bright) and can be used for automation
    Shelly TRV:
    - Force-close option is extended when valve is not fully closed, this option is motor for more pressure during movement. Under 35% battery, this option is automatically activated to solve similar problems.
    - TRV: MQTT password lost after OTA update fixed.
    - The screen may not wake up. Problem is fixed
    - TRV frost protection icon (4 degrees Celsius) is added in device webUI and cloud.
    - Valve clog prevention option is added - valve fully open and close if no other movement in the last 7 days.
    - Open window option is added. When this is enabled, you can send to the unit http://ip/window?state=open/close which sets a different temperature base for the state.
