Script does not start after reboot
Hinweis für Entwickler
  • Hi,
    I uploaded a script to my I4, enabled it and started it.
    Everything worked really nice until I rebooted the I4.
    After reboot the script is stopped and not automatically started as described in the documentation.
    Any ideas? Thanks in advance.
    The script just sends all events to a server in the local network….
  • Admin 8. Juni 2022 um 05:51
    Hat das Thema freigeschaltet.
  • Which Firmware-Version is currently installed on the Shelly Pus i4?
  • ok, I cannot test the script myself as I don't have a node red installed.
    What I tried:
    - created a new script named "test"
    - copied the content from your script
    - started the script
    - enabled the script
    - rebooted the Shelly I4.
    after the reboot the script is still in state running:
    Firmware is 0.10.2, so in general it's working fine.
    Some questions:
    - Do you use additional scripts on the I4? maybe you reached the ressource limits.
    - Have you already tried to delete and re-create the script?
    - will the script start if you edit and click the "save and run" button?
    - Do you use push buttons or switches connected to the inputs? if switches: are they in state "on" or "off" during reboot?
  • I do not have any additional skripts running.
    All I do is uploading a skript from within node red using the api.
    Then I enable the script via the api, too.
    After rebooting the skript is not running.
    I will do further checks after returning from vacation
