Shelly Cloud HTTP Post via URL
  • Hi,
    Is it possible to trigger a Shelly via cloud via URL only?
    eg. https://shelly-41-eu.shelly.cloud/device/relay/control?turn=on&channel=0&id=YYYYY&auth_key=XXXXXXXXXXXXXXXXXXXX
    I can trigger it using Postman with the URL https://shelly-41-eu.shelly.cloud/device/relay/control?id=YYYYY&auth_key=XXXXXXXXXXXXXXXXXXXX and putting the turn=on & channel=0 into the body, but I have a service that wont let me send the body.
    Thanks
  • Hi,
    I think it's impossible, but I can't say for sure. Never found any official info about that.
    Here another person who tried without success.
    cannot save report url
    Seems only status work with direct cloud url.
    "https://shelly-21-eu.shelly.cloud/device/status?id=XXXXXXXX&auth_key=ZZZZZZZZZ"
  • After a lot of banging my head on the wall, because help here on the forum is null, maybe due to lack of knowledge, I came to the following conclusion:
    In the Browser only the following order works:
    - https://<your shelly cloud server>.shelly.cloud/device/status?id=<your device id>&auth_key=<your cloud authorization key
    - https://shelly-21-eu.shelly.cloud/device/status?…***************
    All others I get the same answer.
    {"isok":false,"errors":{"wrong_channel":"Could not control this relay channel!"}}
    I found that if I use the following HTTP Shortcuts.App (http-shortcuts.rmy.ch), everything works perfectly.
    My problem was solved, but it could have saved a lot of time if I had this information from the developers.
    "On the PC Browser these orders do not work."
