Looking for script API for shelly to auto-reboot/restart
Hinweis für Entwickler
  • Hello
    While using cloud API i can ask Shelly to reboot (Shelly.Reboot). I am looking to do the same but by Shelly script from within Shelly scripting engine. The bigger idea is to build a self watchdog. If Shelly goes offline, assume the problem is with the Shelly and auto-reset myself hoping that after boot the wifi will be acquired again. I saw a script example which monitors network connection and when lost - resets the router. I want to reset the shelly itself, not the device connected to it.
    Is there some API for it ? Maybe something indirect like changing some Shelly setting that causes shelly to restart ?
    ThNks
  • Admin 28. Mai 2022 um 06:22
    Hat das Thema freigeschaltet.
  • Hi Luis!
    • What's your longtime experience with the script?
    • Does it keep the shellies online?
    • Can you please make your script available?!
    tnx & haveaniceday!
    ps; such a script remains active & runing even after a .reboot?
    Einmal editiert, zuletzt von Andreas.Wien (10. August 2022 um 03:51)
