Device doesn’t accept to set MQTT via http api
  • Sending MQTT service setup via http api
    Device response to call 404 not found
    Call tested with various number of different devices and it does work with them, but not with motion
    http://192.168.33.1/settings/mqtt?mqtt_enable=1&mqtt_server=[srv-ip]:1883&mqtt_user=[mqtt-user]&mqtt_pass=[mqtt-pass]&mqtt_id={shelly_name}
    No matter if device IP is set or firmware is updated to latest (tested with beta also)
    Einmal editiert, zuletzt von -Teme- (20. Mai 2022 um 20:03)
  • Forgot to add answer how to got this work. I had an incorrect string, but it did work for other models.
    http://192.168.33.1/settings?mqtt_enable=1&mqtt_server=192.168.x.x:1883&mqtt_user=[mqtt-username]&mqtt_pass=[mqtt-password]&mqtt_id={shelly_device_name}
    Einmal editiert, zuletzt von Gast10 (21. Juni 2022 um 09:58) aus folgendem Grund: Code in Codetag gesetzt
