Shelly and Livolo
  • Code
    Hi, if someone can help me because I'm desperate, I have a Livolo touch switch and I can't make it work well, I have connected it as follows:
    The Livolo switch is powered by L and the output to the bulb (L1 load), from here I have put a cable to the SW input of shelly, at the output O of shelly I have put the cable that goes to the bulb ( the same as L1 load), input I and L + fed by phase.
    The touch switch works for me, if I turn the light on with the touch switch, I can turn it off with the shelly app, the problem is that if I turn on the light with Shelly, the touch switch turns off the LED and does not work. Someone could help me?
    Thanks in advance
    I'm sorry, but such touch switches which took the N-potential over the load (bulb) are not compatible with Shelly (not out of the box). If you have an electronic switch you'll need a version which has its own power supply terminals "L" AND "N"and maybe a relay as output. This is the same problem you'll have with many motion detectors.
    Grüße Bernd
    Mein "Smarthome":
  • Thanks for the clarification, I could upload a photo with the scheme with a relay next to shelly for the Livolo to work.
    Einmal editiert, zuletzt von Gast10 (8. Januar 2020 um 17:39) aus folgendem Grund: Code-Tag removed
