I have two Shelly Plus 2 PMs, back to back with each other, in the wall cavity behind a switch. Should I be worried about heat?
Watch the temperature below http://IPplus2PM/rpc/Shelly.GetStatus. With and without load, also activate the ECO mode to reduce the temperatures
Acceptable temperatures? How do I activate CO mode?
You can find ECO mode under Device settings.
Acceptable temperatures 60-85°C (with load)
