Shelly Plus 1pm 0.10.1 - can't leave gateway field empty
  • Hi folks,
    Shelly Plus 1pm f/w 0.10.1 - seems like I can't leave the "gateway" field empty when setting a static IP address. This is required for a local-only setup, and has been part of the recent f/w versions for previous gen devices. It appears as if it was not added to the current firmware.
    Any chance this can be added? Thank you!
    (Workaround: You can specify a nonexisting IP address for the gateway. Needs to be on the local LAN and remain empty. This is suboptimal as the device will keep looking for it, sending out ARP requests and whatnot, and the IP address must remain unpopulated.)
