Pressure Sensor
  • Is there a way to hook up a pressure sensor to Uni. I want to put it on my pool filter measure the pressure as it rises to see when i need to back flush the pump. I would like to add a temp sensor on it as well, that seems pretty straight forward but cant find any documentation on a pressure sensor. Ive bought a pressure sensor from seeed studios. Here is a link to it.
    https://www.seeedstudio.com/Water-Pressure…tailer_products
    thanks for any help
  • Hi,
    yes it shoud work.
    Feed the UNI with +12-36VDC (VCC red) and 0VDC (N black).
    Feed the SENSOR VCC (red) with +5VDC
    Connect the SENSOR OUT (blue) to UNI ADC_in (white)
    Connect the SENSOR GND (black) to UNI INTERNAL GND (green)
    For temperature you can use up to three one wire sensors type DS18B20
    I use someting similar with one sensor for tank-level and two temperatur sensors...
    Viele Grüße,
    Wolfgang
  • hello can you help me in connection
    like > DS18B20 lines what color you give to shelly, while the green already connected to black for tank sensor.
    and do i need to feed the unit also 5v pulse 12v??
    pressure sensor already working .. need to connect DS18B20
  • the pressure sensor will not output more than approx. 3V
    Anbage manufacturer is 5V DC, not 3.3V DC
    Factor: Vout = VCC x (0.75 x P + 0.1), P is Pressure.
