Shelly 1PM overheated
  • Hi,
    A couple of weeks ago I bought a Shelly 1PM to monitor my outdoor heater as I sometimes forget to turn it off. Unfortunately it seems that when using my heater, the Shelly shuts itself off due to a to high internal temperature after approx 1-2 hours. My heater is using 2500 Watt contineously and the Shelly is built into a junctionbox which is in outside air.
    This is a bit dissapointing as I would expect that it's rated for 16A. Is this normal? Anyone a(n alternative) solution for this?
    What I would like to achieve is to shutdown the heater (by shortly cut off the power as it's then reset to standby) after x hour of usage.
    Kind regards,
    Peter
