Bad Sensor?
  • Hello,
    I recently bought a H&T and I'm setting it up. I was able to get it to connect to my network, report in to MQTT broker, and update the firmware to 20220324-134040/v1.11.8-HT-fix-g60b9bd1. The problem I have is, it is reporting a temperature of 999 and humidity of 0. These values never fluctuate. I've rebooted but haven't tried to reset to factory. Did I receive a bad h&t?
    --Mumblingsages
  • Same issue here.
    mumblingsages Any luck finding a fix?
    /status reports:
    {"wifi_sta":{"connected":true,"ssid":"","ip":"192.168.10.181","rssi":-49},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"13:37","unixtime":1651635474,"serial":2,"has_update":false,"mac":"C8C9A3706605","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"is_valid":true,"tmp":{"value":999.00,"units":"C","tC":999.00,"tF":999.00,"is_valid":true},"hum":{"value":999.0,"is_valid":true},"bat":{"value":-1,"voltage":2.75},"act_reasons":["poweron"],"connect_retries":0,"sensor_error":1,"update":{"status":"idle","has_update":false,"new_version":"20220324-134040/v1.11.8-HT-fix-g60b9bd1","old_version":"20220324-134040/v1.11.8-HT-fix-g60b9bd1"},"ram_total":51520,"ram_free":39852,"fs_size":233681,"fs_free":150851,"uptime":24}
