Shelly 1 - access forbidden and cannot update
  • Hi my friends!
    I use one Shelly 1 for my automatic watering system and I've  just noticed I can't open the web interface of my Shelly 1 anymore. All I get is a "Forbidden" message. However I can manage the device through the mobile app. I've tried a factory reset but it does nothing, I still get the same message.
    On top of that the app says there is an update pending but I can't apply it. Here is what I get with a call to https://l.facebook.com/l.php?u=http%3…tJ8ST5PxhoV-w1I
    {"status":"updating","has_update":false,"new_version":"20220209-092750/v1.11.8-g8c7bb8d","old_version":"20210429-100340/v1.10.4-g3f94cd7"}
    Do you have an idea ?
    Thanks
    Ken
  • Hi and welcome to the forum. :)
    I cannot guarantee that it will be successful.
    You can also try the following commands:
    192.168.101.32/reboot
    or
    192.168.101.32/reset
    (new setup necessary)
  • Hey,
    got the same problem here , /reset not found /reboot -> ok:true. Hard reset with 5*switch didn´t change anything either except it goes into its own wifi :-/
    I can join it to the local net with the app but it doesn´t appear then anywhere. It can be reached by the new IP then but with the same result: "forbidden".
    best regards
    Tom
