Shelly 1L not sending command to URL adress
  • Hi
    I have a problem getting a Shelly1L to send a command through URL to a Shelly RGBW2.
    The URL works when i type it in to my webbrowser and the Relay in the Shelly1L responds when i try to turn it on in the app and on the physical switch.
    I've tried to enable "button 1 switched ON URL" and "Output switched ON URL", in the Shelly1L, both separately and combined to the same URL but neither does the trick.
    Any suggestions or does anyone known of an old thread where the issue has been addressed?
  • I use a Shelly 1L (firmware 1.11.8) to send commands to a Shelly Dimmer2 and a Shelly plus 1, and it works fine.
    I use IO actions on :
    Button 1 Long push
    Button 2 Long Push
    Button 2 Short Push
    All works fine. My "Button type 1" is configured as "momentary on release" and "Button type 2" detached.
