4 way without neutral ?
  • I have 4 switches for a couple of lights in my garage. There's no neutral wire, so I guess I have to use Shelly 1L.
    2 switches have 3 wires and 2 switches have 4 wires and are marked with a "4 way" sticker.
    How do I connect a Shelly 1L ? I tried to use the same scheme as with a "2 way" configuration, but it didn't work.
    Thanks for your help!
  • No reliable statement can be made without having measured the wires!
    But here a conversion to a pushbutton circuit would make sense.
    266-ar768-tasterschaltung-ohne-n-bypass-png
    Spoiler anzeigen
  • I did use a Shelly 1L with a 2 way switch in my house.
    First and last switch are the same like in the 2 way configuration. But there are two 4 way switches inbetween.
    And none of my switches are momentary switches, they're old style rocker switches.
    4 Mal editiert, zuletzt von shelmic (10. April 2022 um 01:34)
  • Hi shelmic ,
    if you don't have the permission of the copyright-holder in your 2nd picture to publich this please delete it.
  • For Shelly 1 we have a Connection Diagramm-> 4-way-configuration:
    The problem, however, is the missing neutral.
    Do you have a junction box like in the 2-way connection?
    Spoiler anzeigen
    Einmal editiert, zuletzt von Admin (16. Mai 2024 um 11:49) aus folgendem Grund: Bild wegen Markenrechtsverletzung gelöscht
