Push Button and Dimmer 2 - Electrician wrong ?
  • Hi Gents,
    Im going to do the best explaining my weird situation.
    I had electrician install Dimmer2, now he said he has done it correctly, and it does have a neutral wire. The Wall switch is a push button (you push and unit goes click and goes back to original position)
    Dimmer works but, if the lights have been turned on through the dimmer(through www) if you then press the button at the wall it just makes the light brighter and if you push the button again it brings the lights back to the level it was before. If you turn of lights with the dimmer(www) and then press the button on the wall switch the light goes on, but the dimmer does not recognize that the light is on. Thus if you turn on dimmer lights stay the same and if you turn of dimmer, light stays on, until you press the button on the wall switch again. I have tried changing the settings, and still doesn't change anything.
    Settings currently are :
    Power On Default:
    Restore last mode
    Button Type,
    Edge Switch
    I really appreciate any information or help. I am hoping i can get this to work, so i can install many Dimmer2 in the house. :)
    Thanks
  • Good mornig and welcome to the forum. :)
    Is your wall-switch a dimmer too?
    If yes, this can not work.
  • Hi Stefan,
    It actually might be, ill have to check when I get home. If it is, can I just have the push button switched out to a non dimmable one and it will work?
    Thanks
    Andreas
