Switch Position in Shutter Mode
  • I installed 3 Shelly2.5 to control my Shutters. I used the Shelly App to setup the Shellys.
    My switches are momentary switches. I am using the Home Assistant Integration and Node Red to control the Shellys.
    But I am missing the switch position in the Home Assistant. I want to use the switch position to avoid lock myself out from the house.
    For example, if I the up switch is pushed the automatization should be blocked to roll down the shutter once the sun sensor wants to roll down the shutters.
    I don't know whether this is an issue of the HA integration or the Shelly firmware.
    Einmal editiert, zuletzt von AWSb24 (4. April 2022 um 19:19)
