Missing options in 4PM web interface?
  • I've installed two 4PM's in my circuit box. One of them is controlling my router equipment so after a reboot or something, that channel should always turn ON, otherwise I can't reach anything - including the shelly.
    I've read at Script to auto turn-on a switch if turned off that I would be able to set this up using Timers.
    But I'm missing that option in the webinterface? Both Shelly's only show the "Device", "Networks" and "Scripts" menu items. I'm running the latest firmware v 0.10.1
    How can I reach the Timers function?
    (not using Cloud connection, disabled AP, connected through LAN and MQTT).
  • Never mind, found out I can click on a channel for way more options! Not too obvious but at least I'm not missing anything. Found the option of default power on.
