- Offizieller Beitrag
©2019 Stefan K. (alias 66er)
Attention:
This coupling is no longer executable with the firmware 1.6.3
Hello everybody,
to integrate the Shelly Door / Window in Homematic, you don't need any 3rd party firmware that you have to flash.
Below is my solution with the original firmware:
techn. requirements:
- compatible with the Homematic systems CCU2, CCU3, Charly, as well as all offshoots such as RaspberryMatic and piVCCU.
- installed addon CUxD in current version
(At this point, I assume that I know how to use CUxD, e.g. how to create devices, otherwise this manual "explodes". Thank you for your understanding.)
The advantages from my point of view:
- very low price (19.90 €) compared to the Homematic original (from 29.95 €)
- more properties can be used
- all Shelly Door / Window properties are retained because I operate the Shelly with the original manufacturer firmware
- all future Shelly Door / Window updates / updates will be available
- full Shelly app usability parallel to Homematic automation
- Operation as a local solution or via Shelly cloud, additionally Homematic
So far I have implemented the following functions on the Homematicsystem:
- Status display of the magnetic contact (open / closed)
- Update of the integrated values with every transmission (battery status, brightness)
- Optional monitoring of the cycl. reporting = failure monitoring and in case of failure e.g. email delivery
The view of the connection:
I would like to recommend you, especially beginners, to take a look at this thread before implementing:
- Important information about the Shelly couplings on Homematic
- Shelly with activated restricted login & homematic coupling
Please follow the instructions carefully from top to bottom when copying. ![]()
Otherwise, as always:
If not yet available, please create a device (28) System Exec! The commands are issued above this. (No entries are made in the CUxD-Exec!)
Have fun and good luck with it.![]()
