Shelly Plus 2 PM never upgrade using Unifi Ubiquiti access points
  • ediazrod 1. April 2022 um 11:51
    Hat den Titel des Themas von „Shelly 0.11.0 Version of gen2 update commands“ zu „Shelly 0.10.1 Version of gen2 update commands“ geändert.
  • What is the result of:
    http://192.168.xxx.xxx/rpc/Shelly.Update
    ip of your shelly please!
  • Code
    {"code":-114,"message":"Resource unavailable: No update info!"}
    This is the result..
    show to the cloud as connected.
    Cloud
    Connected: shelly-api-eu.shelly.cloud:6022/jrp
    {"ble":{},"cloud":{"connected":true},"cover:0":{"id":0, "source":"init", "state":"stopped","apower":0.0,"voltage":239.6,"current":0.000,"pf":0.00,"aenergy":{"total":0.000,"by_minute":[0.000,0.000,0.000],"minute_ts":1648886511},"temperature":{"tC":37.1, "tF":98.8},"pos_control":true,"current_pos":null},"input:0":{"id":0,"state":false},"input:1":{"id":1,"state":false},"mqtt":{"connected":false},"sys":{"mac":"A8032AB6XXXX","restart_required":false,"time":"10:01","unixtime":1648886511,"uptime":196,"ram_size":237844,"ram_free":131092,"fs_size":458752,"fs_free":221184,"cfg_rev":20,"available_updates":{"stable":{"version":"0.10.1"}}},"wifi":{"sta_ip":"192.168.142.239","status":"got ip","ssid":"XXXXXXXX","rssi":-55}}
    {"ble":{"enable":false},"cloud":{"enable":true,"server":"shelly-api-eu.shelly.cloud:6022/jrpc"},"cover:0":{"id":0, "name":"Sotano.Hall.XXXXXX", "motor":{"idle_power_thr":2.00},"maxtime_open":60.00, "maxtime_close":60.00, "initial_state":"stopped", "invert_directions":false,"in_mode":"dual","swap_inputs":false, "safety_switch":{"enable":false, "direction":"both", "action":"stop","allowed_move":null},"power_limit":2800,"voltage_limit":280,"current_limit":10.00,"obstruction_detection":{"enable":false, "direction":"both", "action":"stop", "power_thr":155, "holdoff":1.00}},"input:0":{"id":0, "name":null, "type":"switch", "invert":false,"factory_reset":true},"input:1":{"id":1, "name":null, "type":"switch", "invert":false,"factory_reset":true},"mqtt":{"enable":false,"server":null,"user":null,"topic_prefix":"shellyplus2pm-a8032abXXXX","rpc_ntf":true,"status_ntf":false},"sys":{"device":{"name":"Sotano.Hall.XXXXXX","mac":"A8032ABXXXX","fw_id":"20220214-154302/0.10.0-beta3-gd36941f","eco_mode":false,"profile":"cover"},"location":{"tz":"Europe/XXXXXX","lat":40.XXXXXX,"lon":-3.XXXXXX},"debug":{"mqtt":{"enable":false},"websocket":{"enable":false},"udp":{"addr":null}},"ui_data":{},"rpc_udp":{"dst_addr":null,"listen_port":null},"sntp":{"server":"time.google.com"},"cfg_rev":20},"wifi":{"ap":{"ssid":"ShellyPlus2PM-A8032AB6XXXX","is_open":true, "enable":false},"sta":{"ssid":"XXXXXXXX","is_open":false, "enable":true, "ipv4mode":"dhcp","ip":null,"netmask":null,"gw":null,"nameserver":null},"sta1":{"ssid":null,"is_open":true, "enable":false, "ipv4mode":"dhcp","ip":null,"netmask":null,"gw":null,"nameserver":null},"roam":{"rssi_thr":-80,"interval":60}}}[/
    2 Mal editiert, zuletzt von ediazrod (2. April 2022 um 10:07)
