Hello!
I recently purchased two shell duo bulbs, direct from Shelly, these are the white versions, not the color.
One of the bulbs works great. The home assistant integration detected it immediately after it was put onto the WIFI.
However, the other bulb seems to be a problem child. It is on the network, but I had to force it to upgrade the firmware, as it would not detect a new version.
The home assistant integration does not auto-detect this bulb. When I try to add using the IP address, the plugin just says "Aborted!' That's all I get.
I see both bulbs on MQTT, but one just does not want to connect to HA
Anything else I should try?
Thanks!
