Reaction on MQTT command
  • I am trying to control my shelly plug S via MQTT.
    I use Mqtt explorer to see if the messages arrive correctly.
    The shelly is reporting its state correctly.
    When I sent a message with the same topic and content no reaction is observed. The plug does not switch on or off.
    How can I get the plug to react? Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
    2 Mal editiert, zuletzt von eporocrail (20. März 2022 um 10:42) aus folgendem Grund: I managed to solve the problem The topic to publish the command should read: "shells/appliance id/relay/0/command" The commands are: on, off or toggle e.g.: mqttClient.publish("shellies/fan/relay/0/command", 0, true, "toggle"); mqttClient.publish("shellies/fan/relay/0/command", 0, true, "on"); mqttClient.publish("shellies/fan/relay/0/command", 0, true, "off");
  • Gast10 13. März 2022 um 12:24
    Hat das Thema aus dem Forum Shelly Plug S nach MQTT verschoben.
  • I managed to solve the problem
    The topic to publish the command to should read:
    "shellies/appliance id/relay/0/command"
    e.g.:
