Authentication not possible
  • I tried to switch on Authentication.
    1) The activation uses only 1 password field and doesn't ask the user to verify the password - this is bad.
    2) There is no "username" field.
    3) When I try to operate a switch via iPhone app, I get an authentication dialog (as expected). This dialog has a username field with "admin" pre-set, which you cannot change.
    4) Entering the correct password doesn't succeed.
    5) So I had to switch off authentication in the browser again. After that, I could operate the switch again from the iPhone app without getting asked for authentication.
    See images:
    Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.    Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
  • Known issue.
    Fix is in progress
