Strange battery reports
  • I have 5 H&T and one of them has a strange behaviour.
    Despite having replaced the battery with a new one, each time it reports values it reports "strange" battery values (see attached screenshot).
    Most of the time it reports battery 0% but working normally.
  • Please call x.x.x.x/status in your browser and post the result here in code-tag.
    (Don't forget to wake up the H&T).
    {"wifi_sta":{"connected":true,"ssid":"","ip":"192.168.1.125","rssi":-59},"cloud":{"enabled":true,"connected":true},"mqtt":{"connected":false},"time":"17:56","unixtime":1646927781,"serial":1,"has_update":false,"mac":"C45BBE760F82","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"is_valid":true,"tmp":{"value":8.75,"units":"C","tC":8.75,"tF":47.75,"is_valid":true},"hum":{"value":84.0,"is_valid":true},"bat":{"value":0,"voltage":2.52},"act_reasons":["button"],"connect_retries":0,"update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20211109-125452/v1.11.7-g682a0db"},"ram_total":51536,"ram_free":39832,"fs_size":233681,"fs_free":156122,"uptime":2}
  • Code
    ...,"bat":{"value":0,"voltage":2.52},...
    Have you a measurement equipment to verify the 2.52 V of the battery?
    If there are realy 2,52V your new battery, bad is the reason. ;)
