How to flash a Shelly 1???
  • I sent the following help request to Shelly technical support:
    I wired a Shelly 1 to an electrical cord and plugged it in. I connected my phone to the WiFi network created by the device and changed the device’s internet settings so that it would connect to my local LAN. I was then able to access the device from my desktop computer. Thus far, no issues.
    I then tried to ‘connect’ the device to my Home Assistant system. I added the Shelly integration and it asked for a host. I entered the host IP of the device, clicked submit, but was shown the error ‘Failed to connect’ (which is odd since I can access the device via a browser). I figured that the firmware on the device could be old and that it needs to be updated.
    On the device’s webpage, I clicked on Settings->Firmware Update and saw the message "The current Firmware version of your Shelly device is 20191217-140757/1047-long-id-for-shelly-devices@a0661583 No newer firmware available. " This firmware is more than two years old and needs to be updated. I found this site http://archive.shelly-tools.de/, entered SHSW-1 as the type and generated the the needed URL. When I put this in the address bar of the browser, I saw this: {"status":"updating","has_update":false,"new_version":"","old_version":"20191217-140757/1047-long-id-for-shelly-devices@a0661583"} which means that the device did not update.
    Shelly tech support replied: do a factory reset of the device from the webUI, then connect again the device to the WiFi, connect the with the cloud and update the firmware. I was able to reset the device, but when I tried to update, I had the same issue.
    They also said: If this doesn't work, then re-flashing the firmware of the device will help. Okay, but no information was provided about how to re-flash the firmware! I was able to download a zip file with the .bin file, but now what?
  • When on the webUI, does the device show the correct time? If not, there is an issue with internet connection and the shelly has no internet access.
    I installed a Shelly1 last week and it did find the current firmware, once the device was connected to my local network. I can't see any mistakes reading your procedures. http://<yourshellyIP>/ota?url=http://archive.shelly-tools.de/version/v1.11.8/SHSW-1.zip is the current firmware. You might try an older release as an intermediate step, maybe this works.
  • Hbrui: Thank you. On the device, I set the time zone and long/lat, confirmed that the sntp server was set, but the time did not appear in the upper right corner of the webUI (after waiting 10+ minutes). Per your note, this suggests and issue with the internet connection – for what should I look? Is it possible that someplace I have tightened things down too much?
    With regard to your comment about trying an older release, I already tried that, but got the same results.
    I think I figured out the internet issue - I had to add the Shelly device to router.
    Einmal editiert, zuletzt von gproston (8. März 2022 um 05:13)
