Quelle: https://shelly-api-docs.shelly.cloud/gen2/changelog/
Unreleased
[script]Available as 0.10.0-beta6.
[/script]
Added
- New HTTP.Request RPC method with support for
GET,POST,PUT,HEADandDELETE. - Cover component
- Only applicable for multi-profile devices: RPC methods Shelly.ListProfiles, Shelly.SetProfile;
profilekey in the responses of Sys.GetConfig, Shelly.GetDeviceInfo and /shelly - Support for
/otaHTTP endpoint, for backward compatibility with Gen1 devices. - Embedded web now has UI for changing the display brightness on Pro4PM
- Device name (if set) is now shown everywhere in the UI of embedded web to ensure users, using multiple browser tabs, would know on which device they are making their changes
Changed
- Switch: setting
power_limittonullwill apply the default overpower threshold instead of disabling overpower protection. - MQTT: do not show
passin response ofMQTT.GetConfig - Change response format of Shelly.ListProfiles
- Improved Plus I4 UI in embedded web
Fixed
- Scripts: Fixed Status change notifications being duplicated as Event notifications.
- Webhooks: fixed decoding of URLs containing the
"character. - Power factor measurement on Pro4PM.
- Initial/on start up power metering improvements
WiFi|Eth.SetConfig- fixed ipv4mode invalid argument error message- Ethernet improvements that should fix some issues with devices hanging/crashing
- Embedded web - Wrong channel name was displayed on Plus I4
- Disable SMP (Symmetric Multiprocessing) on all devices
