Feature request: assign favorite positions to physical buttons/switches
  • Hello,
    I am using several Shelly 2.5 for shutters and rollers.
    I would like to propose a new feature:
    Make it possible to use the physical buttons to move the shutter to a favorite position instead of the default 0% and 100%.
    The use case is this: My internal rollers are position 50cm above the windows so when I press the physical 'open' button, i would like the roller to move to the 90% position instead of the 100%. At 90%, the roller's fabric has fully moved above the window, yet it's not technically fully open, it still covers part of the wall above the window
    I tried to add a Scene to do this (when position is 90% then stop), but it doesn't seem to work (does a Scene gets notified of the current position in real time? It doesn't seem to be the case).
    If this feature can be accomplished in any other way, I would really appreciate any pointers,
    Thanks
  • Costas Stergiou 1. März 2022 um 18:30
    Hat den Titel des Themas von „Shelly 2.5 shutter fully open/close position calibration“ zu „Feature request: assign favorite positions to physical buttons/switches“ geändert.
  • hello Costas Stergiou,
    Here is the right place for your suggestion / Feature request.
    https://shelly-forum.com/suggest/
  • It should be possible with I/O URL if actions for button was available.
    Unfortunately with shelly 2.5 in roller shutter mode, even if button are in detached mode, actions are only available for roller open/close/stop, not for button.
