TRV + Door/Window
  • It's not really straight forward what to do when you have to combine this two devices. So after some experiments, I came up with some questions.
    My current setup:
    In the Door/Window settings "Actions":
    OPEN WHEN DARK/Twilight/Daylight: Fill in as URL "http://TRV-IP-ADDRESS-HERE/settings/thermostat/0?target_t_enabled=0"
    CLOSE: Fill in as URL "http://TRV-IP-ADDRESS-HERE/settings/thermostat/0?target_t_enabled=1"
    This works ... from time to time.
    I guess this is related to the response time of the TRV. Sometimes when it's "sleeping" it's responding really slow ... but the D/W sensor has limited time awake.
    So is there a way to tell DW to wait more time for response? Is there oficial information about the timeout for this endpoints?
    I'm trying to make this 2 work togather for a long time and they just doesn't work as expected.
    Possible solution is request to the cloud ... but I can't make real authentication with static url.
    I can't use the trv local domain, again because of request time.
    I can use a hub ... but the main marketing point for Shelly is ... no hub needed.
    Any ideas?
