Shelly I3 & Livolo & Dimmer2
    Hi All
    I have a problem with this implementation. I want to have the I3 working on three of the Livolo toggles and one connected to the Dimmer2. The problem is that the I3 when configured as toggle switches does not change state when the switch is activated. I have tested the switch and tested the I3 on another switch. Is there something I am missing in this diagram?
    The switch on the Dimmer2 will not function at all.
    The Livolo Switch is an electronic tactile switch
    https://www.livolo.com/es/catalogDeta…WG,VL-C902S-3WG
    Thank you for your help.
    AB
