MQTT AND Native HA integration - at same time?
  • Hiya!
    I just got 3 shelly relays and set them up in HA via the native Shelly integration. However, I heard MQTT is 'faster' so I set up an MQTT broker and used the autodiscovery script to get all 3 relays into HA. I thought this would make redundant devices and I'd just go back and delete the ShellyNative integration/devices.
    HOWEVER, it looks like HA understood that these are the same devices. It shows 1 device and lists both integrations.
    Should I still delete the shelly integration? If I leave it as it is now (with both native and mqtt integrations installed), does it know to use the 'better/faster' MQTT communication?
