Failed to resolve 'iot.shelly.cloud'
  • Hi all.
    I'm a newbie on shelly.
    I have buy 2 shelly 1 and I have a problem with a one of this.
    Both are configured the same, same WiFi, same settings, static IP, but one can connect to the cloud the other cannot.
    I have enable debug and this is the log:
    11231578630 mongoose.c:12126        Failed to resolve 'iot.shelly.cloud', server 8.8.8.8
    11231584601 cloud_aes.c:256         Connect to cloud: -1
    But this is not possible, because the second shelly is connected and, for example, the ping to hostname working fine
    Can someone help me?
    EDIT: I have found a workaround.
    If I setting a DNS (also 8.8.8.8) on WIFI MODE - CLIENT section, the connection work
    Regards,
    Marco
    Einmal editiert, zuletzt von SirLancillotto (19. Februar 2022 um 18:05) aus folgendem Grund: Found workaround
