Plug S not compatible with Europlug?
  • Today I unpacked my first order of Shelly devices.
    Starting with a Shelly Plug S, I connected it to an outlet and a small desk-lamp.
    After establishing the wi-fi connection to the plug, I could hear the plug relay switching on and off when toggling the status in the webapp, but my lamp was dark no matter what.
    At first I thought the small LED was too weak to trigger the relay but when I tried something more powerful like a sewing machine I noticed that it was in fact a huge wiggle room that made the europlugs on these two devices loose their connection to the plug.
    Here is a video to clarify
    Is this really what to expect from these S-plug, or have I encountered a bad apple?
  • Unfortunately we cannot see the profile of your europlug. Sometimes the manufacturer of those lightweight plugs are not very firm with the standards. What happens, if you let two or three millimeters of space between plug and socket while plugging in? If the insulated shaft is a little bit too long this behaviour also will be seen...
    Otherwise you can open the plug S by screwing trough the hole in the earth contact at the plugside and bend the contacts to your needs...
  • Hi Mikael-S
    Unfotunately this is somewhat a manufacturing failure but it is easy to fix.
    You'd have to open the plug. there's a small screw between the pins on the downside.
    Once it is open use a small pin to pull the copper clamps to the inner side.
    I've made a more detailed description (including a picture) in german here:
    Seven of Nine
    10. Januar 2021 um 21:09
  • I just unpacked my first Shelly Plug S and can confirm the same issue. Thanks for the tip! I will try it tomorrow.
    /L
    Einmal editiert, zuletzt von Gast10 (17. Februar 2022 um 04:10) aus folgendem Grund: Full quote of last tread deleted
  • Thank you Seven of Nine and rallyecom
    It seemed easy enough, but then I got the bad idea of testing the connection without reassembling the plug and that left the europlug stuck in the S-Plug since it will sit much deeper this way and the connecting surfaces edges somehow is locked by the copper clamps...
    So don’t do it like that Limeliz
    I'll see if i'll cut the cord and crush the europlug with a pair of bolt cutters or something to save the S-Plug.
