React on Power-Measurement possible without Cloud? (Webhook or Scripting)?
  • Hello,
    I want to moitor a drainage pump. If the pump starts working, the consumed power will increase.
    If this happens, I want to call a URL.
    a) Is it possible to setup a a webhook with an adjustable power threshold?
    b) Can the power value be accessed by scriptiing?
    Thanks in advance
  • Hello Seven of Nine ,
    i was able to play with your example. (I'm using the 1 Plus 1PM)
    Two weird things happened:
    1. I do receive the power value and can use it in an if for comparision.
    But I can't print the value with the print() function.
    2. I also can't set a variable with its value and do some calculations.
    I always get:
    implicit type conversion is prohibited
    Do you know, what the problem could be?
    Do I need a kind of type-cast?
    Best regards
  • 1) maybe the value is not properly detected
    2) there's probably a type conversion needed.
    Would you mind sharing your unfinished script?
