HELP SHELLY DW2 DEAD
  • Hello Everyone
    I bouth a pack of 4x Shelly DW 2 in last december.
    Until now they were running perfetly and working like it should, unfutunatly of the 4 sensors at this moment only one is working the other 3 are offline I already tried to use new bateries proceed with the a reset and none of 3 sensors are working.
    At the begining I think that was a defect of the sensor but now it happen to 3 of the 4, what can be cause to this happen?
    They are in a plce with low values of humidity and the temperature range is bitwin 12 and 19ªC
    Thanks for the help
  • Hello,
    same here with me. In the beginning all 4 were working fine, but then quickly after a few weeks one after the other went dead. I thought it was a bad battery batch (Ansmann via Amazon) and ordered new ones (no-name brand this time...). With this only one of my 4 sensors is working. Wasn't sure if this was a bad battery batch as well -> now I bought only two new batteries (Energizer) as 8 batteries cost quite some money... I tried re-setting and everything with two sensors, but both seem to be dead... Is there another way to factory reset than described in the manual? I am thinking of returning them to Shelly, maybe a bad batch on the sensors?
    Thanks!
  • Nothing but trouble here too. With difficulty and inconsistent responses, I finally got 2 sensors (DW2) on the App. At first, they noted open and close and all their configuration options. But, after a day, they've gone to sleep and show as OFFLINE. I press a button and get a red light but the app still shows offline. Not sure where to go from here.
    (update) - As noted above, with much difficulty and a few weeks later it seems my D/W 2 sensors are operating as expected. I do not know why.
    Einmal editiert, zuletzt von EdZ123 (26. Juni 2022 um 22:40) aus folgendem Grund: Update
  • I have 5 sensors since last year. At first they all worked fine. After a while they began to have battery drain issues which I solved replacing the batteries. Currently 2 of the sensors are working fine but the other 3 are offline, not responding to battery replacement at all. Nothing happens pressing the button.
    I followed this post hoping to have an answer to my problem but so far that didn't happen.
    I would appreciate if anybody could have a solution for this otherwise, given the facts already described by others, I'll be forced to conclude this devices are a bad deal.
