Energy dashboard Shelly plug s not showing current value and not logging
  • Hello,
    i have two "shelly plug s" (Firmware: 20220209-094058/v1.11.8-g8c7bb8d) integrated into home assistant (version Release 2022.2.6 - February 11) with core integration addon for shelly. Devices "shelly plug s" are showing usage values on own website of the devices (watt usage) and within the device/entity overview (entity power, for example 2,3 w) in homeassistant. The second entity "energy" has never values with active end users.
    I can not add entity "power" to the standard energy dashboard as "single device", only the entity "energy" can be added and there are now values shown and logged. I waited a day but no actual or historical values are shown in the dashboard.
    Shelly plus s is connected to cloud and CoIoT peer is HomeAssistantIP:5683 (unicast), sntp server works and is pool.ntp.org.
    Whats wondering me is, that entity "energy" (kwh) has never values.
    I have five tp-link (HS110) plugs which are working fine and showing results in the energy dashboard.
    Can someone find an error and help me please?
    kind regards
  • I saw the same behaviour. If the clock in the Plug S is not set, the energy readings will not work.
    If you see "timestamp":0, in a response to http://ip-address/meter/0 in your browser, the energy reading for your device will not work because it's clock is not running.
    I just created an Allterco ticket with the below questions:
