shelly door/window 2
  • Bonjour je viens de recevoir plusieurs capteurs porte/fenêtre 2 je cherche comment recevoir des notifications lorsque la fenêtre s'ouvre ou se ferme via l'application shelly sur ios ?<img src="https://www.shelly-forum.com /images/smilies/emojione/1f61c.png" alt="8o" class="smiley" srcset="https://www.shelly-support. eu/images/smilies/emojione/1f61c@2x.png 2x" hauteur ="23" width="23" chargement="eager" data-tooltip="w00t" aria-label="w00t" id="wscSmiley_0_0">
    Je vous remercie
    Einmal editiert, zuletzt von Loetauge (6. Februar 2022 um 09:49) aus folgendem Grund: Code Tag entfernt
  • Hello,
    sorry to answer in English, but the only thing worse than my English is my French! You can set up alarm zones, then when you activate them an alarm will be sent to your phone when a door or window opens
    After you have set up the zone, you can find it here and then activate or deactivate it when you are at home, for example
  • Robert_M. 6. Februar 2022 um 10:39
    Hat das Label von Door / Windows auf Shelly D/W2 geändert.
  • Sure, with scenes.
    For example:
