Dimmer2 flickering / flashing issue - Testfirmware
  • @ all with flickering problems on Dimmer2, if you want, can you please help to narrow down and reproduce the error?
    A test firmware was provided, which must be loaded via OTA.
    Method:
    -Install test firmware (link below), turn on dimmer and observe
    -Once the flickering is gone, reduce the brightness to minimum, if the light can still be seen, check for flickering, then increase to over 80 percent and check again.
    It is important to create a debug log after the tests and send me the result as a text file in a conversation/private message at best.
    The debug log can/should be activated immediately after installing the test firmware in the WEB UI under Device Info:
    Link to test firmware:
    http://IPfromDimmer2/ota?url=http://repo.shelly.cloud/firmware/dimo/SHDM-2a.zip
    Thanks for the help....
  • Great work that this issue is being investigated.
    I have updated my devices right now and will send logging as soon as I have something usefull.
    Does this firmware already have certain improvements in it regarding the 'random' flickering of LED lights?
  • Indeed great that this issue is being investigated! I've updated one of my dimmers a couple of hours ago and it didn't flicker yet since (before the update I noticed one blink about once an hour). I will send the log by private message and do some more testing with my others dimmers.
    Einmal editiert, zuletzt von goochelaar (7. Februar 2022 um 23:16)
