HELP! How to Shelly Dimmer with PUSH DIM led light?
  • Hello,
    I'm new to the Shelly world and I want to start good!
    I'm renovating the house and want to install shelly products for the lights in each room.
    In particular, in the living room I will have a dimmable wall light, that is sold with its push dim driver (see here the attached file with wiring diagrma).
    My question is: what do I need to correctly dim this light with Shelly?
    A Shelly dimmer 2? how do I wire it, considering there will also be the driver?
    Or do I need a Shelly 1 instead?
    I want to be able to turn on-off and dim from the app.
    thanks!
    Matteo
  • I am interested in this answer as well since I plan installing a lamp over my kitchen counter that also has a "push dimmer" option and I want to be albe to dim it with a shelly device.
    Were you able to get any answer?
