Firmware 1.11.8-rc2 for Gen1 devices is released for wide testing
  • Firmware 1.11.8-rc2 for Gen1 devices is released for wide testing.
    You can update devices from their webUI.
    New features and improvements:
    • ECO MODE (except battery operated devices) added
    • Add Discovered devices status in /shelly
    • Retry mechanism for Shelly HT actions - should improve TRV control
    • Shelly1/1PM + ADD-ON - reporting URL to control TRV
    • Reboot command via MQTT added
    Solved issues:
    • Sensor URL actions cannot be saved for 3rd sensor (when using temp addon)
    • Shelly Button 1 drops from Wi-fi before button event response is received when battery powered
    • Shelly button - device does not work with unicast & DHCP
    • False Overpower alarm on Shelly Plug S
    • Battery devices fixes in status packet to cloud
    • DW2 Broken cloud command handler for led status disable DE
    • Shelly EM - auto on/off does not trigger with schedules
    • Shelly Plug-S: duplicate JSON key led_status_disable
    • POST requests to /settings/actions not working
    • Shelly HT - Humidity threshold cannot be set under 4 from WEB UI.
    • Shelly 2.5 - Relay mode - Cycle Switch on SW1
    • Shelly EM - Add support for power factor in CoAP and MQTT
