Dim to Warm
  • Hello, If using a dual white LED-strip with warm/cold white LEDs on a separate channel.
    Is there a function in the RGBW2 to program in two curves or simillar such that when you
    dim down, it reduces the cold white LEDs and increases the warm white LEDs brightness
    to give the appearance that the temperature of the light decreases?.
    Also what fundamental PWM frequency and resolution is used on the RGBW2 and can this frequency/resolution
    be changed in web interface or in shelly app to avoid flickering?.
    Thanks /Peter
