Double timer error
  • Ok so when I set my Shelly 2.5 auto off for channel 0 it works no problem then I wanted the relay to turn back on with timer so I also set auto onbut with 5seconds to go the timer continually resets itself back to 9 or so and loops so I'm assuming the auto on/off functions share the timer? I dont know
    Next I tried using the DDD link for the same purpose with output off url calling
    http://localhost/relay/0?timer=300&turn=on
    But again same timer loop runs down to 5s the back to 9s then back to 5s and stays stuck in loop. Am I doing something wrong? Or is it not possible?
    I'm trying to create a repeating delay cycle timer so
    For example: relay on for 3min then off for 9min then start again
