Dimmer 2 controlled by SW1 and capturing SW1 to control a scene
  • Hi,
    I have a dimmer 2 controlled by a momentary switch connected to SW1 controlling the ceiling lamp in the same room. It work as expected. Now I would like to control a Shelly1 in the next room from the same wall switch location wheredimmer is. I would like to connect a second momentary switch to SW2 and forward the event to the Shelly1 in the other room. Is this possible in the Shelly app?
    2 momentary buttons connecting to Dimmer2, SW1/SW2.
    -SW1 Controlling the dimmer it is connected to.
    -SW2 Controlling a Shelly1 in another room (no cable connection)
    I hope someone already did this but cannot find any info if this is possible (or not).
    Thank you
  • I'm looking for something like this as well, only with regular switches. What i can find on the forum and docs (Shelly Dimmer 2), it is not a 'simple' config setting. Instead I'll be setting the button type to edge mode and handle this in Home Assistant or WebUI...
