Shelly 1 reading json status in Python
  • Hi All... I am hoping someone else has tried reading the json messages from the Shelly 1 into Python. I am creating a small GUI to try and get the status of the relay before sending a command thru URL/HTTP request. I can return status from Python, but cannot determine which portion I need to try and read so I can see the json part of it "ison"=true or false. If anyone can assist me with this, that would be great.
    Einmal editiert, zuletzt von Mikeg71 (23. Januar 2022 um 03:37)
  • You can use the urllib.request and json lib
    Here an little Example:
    [script][/script]
    [script]
    [/script]
    [script]import urllib.request as request [/script]
    [script]import json [/script]
    [script]
    [/script]
    [script]with request.urlopen('192.168.xx.xxx/status') as response: [/script]
    [script]if response.getcode() == 200: [/script]
    [script]source = response.read() [/script]
    [script]data = json.loads(source) [/script]
    [script]else: [/script]
    [script]print('An error occurred while attempting to retrieve data from the API.')[/script]
    [script]
    [/script]
    [script][/script]
  • To Read objects:
    example:
    shelly_api = {}
    for i in range(len(data)):
    team, api_endpoint = data[i]
    if api_endpoint not in shelly_api.keys():
    shelly_api[api_endpoint] = []
    shelly_api[api_endpoint].append(status)
