How to avoid the "long press" event
  • Ciao,
    i have a few Shelly 1s each connected to a local external switch, which is configured as "detached" from the local internal relay. I'm handling them through Home Assistant and everything is working fine but a small problem without practical impacts: the Shelly 1s are sending a "long press" event when the external swicth is switched to the on position and my Home Assistant registry is getting somehow "polluted" by those events that I don't handle ('casue they are not really informative, in the presence of an external real swicth, instead of a momentary button).
    Is there a way to configure the Shelly 1 not to send the "long press" event at all ?
    I tried setting the the "long push" time to 0ms in the Shelly 1s local configuration, but that value is not accepted by the UI.
    Thank you and ciao, Nicola.
