MQTT Nightmare
  • hi@all
    1st: i've more then 2 dozen shellies: H&T, buttons, bulbs, plugs, motion, ect.
    all are connected to the same mqtt broker with username+password and a custom mqtt prefix
    the mqtt broker is an eclipse mosquitto ver. 2.0.11 running on debian buster
    so trust me, i'm a bit experienced in it
    No chance at all to get the TRV communicating with it!
    Strangely enough, the TRV is sending data to a mosquitto ver 1.5.7 w/o username+password
    i've to say i was not expecting a green banana because all others shellies are working well with mqtt
    p.s.
    yes, latest fw and factory restet also done
    Einmal editiert, zuletzt von dErnest (15. Januar 2022 um 11:30)
  • i configured my MQTT in Openhab like this:
    ------------------------------------RECEIVING---------------------------------------------------------
    MQTT State Topic:
    shellies/shellytrv-SHELLY-ID/info
    Transform Values - Incoming Value Transformations:
    JSONPATH:$.thermostats..tmp.value <-- measured Temperature
    JSONPATH:$.thermostats..target_t.value <-- SET-Temperature
    ---------------------------------------SENDING------------------------------------------------------
    MQTT Command Topic:
    shellies/shellytrv-60A423D0D034/thermostat/0/command/target_t
    Maybe this helps you
