DDD from Shelly Flood does not work
  • I am trying to send DDD from a Shelly Flood Sensor to a ShellyPlug, but the ShellyPlug does not switch as expected
    Shelly Flood sensor:
    IP: 192.168.0.191
    Command configured when rain is detected: http://192.168.0.179/relay/0?turn=on
    Firmware: 20211109-125548/v1.11.7-g682a0db
    Shelly plug
    IP: 192.168.0.179
    Firmware: 20211109-130223/v1.11.7-g682a0db
    My test PC connects to both devices, the state of the plug changes when DDD is sent from browser but not when sent from the sensor. The sensor detects water and can control relays via a scene on Shelly Cloud.
    When setting a DDD action on the sensor via Shelly Cloud the configuration change is confirmed but when going back to the same page the configuration has been lost.
    There is an old post with similar problem solved by upgrading to v1.9.1. Has the issue returned? Does the clould actually change the setting? Does the sensor actually send any DDD?
