Shelly TRV - Firmware 2.1.1_RC2 is ready to test
  • Source: Facebook (Dimitar Dimtrov)
    Update command :
    http://TRV_IP/ota?url=http://repo.shelly.cloud/firmware/test/SHTRV-01_build.gbl
  • TRV continues to heat after reached the optimal temperature. It's like this for hours.
    In the same time: Valve position: 100 %
    Is there a debug log that I can shere or some other way to make your life easier with this kind of issues?
    I restarted the device 5min after the screenshot. The current temperature after restart was "26.6 C". Looks like this is the actual temperature, because it stays the same even after 5-10min.
    2-3min after the restart the valve was closed.
    General observations from this update: The valve is more dynamic (changes position more regularly) and it looks like it does better work then the previous one.
    Einmal editiert, zuletzt von realbudhead (13. Januar 2022 um 13:31) aus folgendem Grund: Added more details
  • Is there a debug log that I can shere or some other way to make your life easier with this kind of issues?
    http://ip_TRV/debug/log
    try with reboot, wait 20min & report please
