Hi,
I bought Shelly RGBW2 and wired it successfully. I was also able to add it to my network via the Shelly Android app and can access it locally via the local IP it got. I can control individual channels from within there fine. But:
1. I cannot connect it to the cloud. When I try it during adding the device, it just shows "Connecting" and later time outs telling me "check the device is powered connection". When I do it via WebUI, it shows up in https://home.shelly.cloud/#/room/3, but is just "Offline" (although I can control it OK locally). I have no weird router settings what so ever, everything worked fine in the past.
2. Secondly, I really cannot control it from the app - it tells "Unsupported firmware version - master. Please update your device. But when I click on "Update", it tells me "Something went wrong" (totally useless error message btw.). I checked the forum and found out that it might be because of cloud not being connected, but see the above, I cannot connect it
I did try factory resetting the device, or adding a static IP and gateway address Issues Integration in the App Shelly Cloud . All the same.
Anyone knows how to solve that, please?
