7. Januar 2022 um 00:11 Autor #1 Have installed a temperature add on on a shelly 1 with fw 20211109-124958/v1.11.7-g682a0db and the temperature doesn't get displayed
7. Januar 2022 um 07:51 #2 The Shelly must be disconnected from the power supply, only then installing the add-on.Which sensors were used in addition to the add-on?The blue clamps supplied are often faulty.Use original WAGO terminals or connect the thin wires with solder.
