You do not have permissions to view this device!
  • ,Hello,
    I get an error while trying to do a simple device status request.
    This the the error,
    {    "isok": false,    "errors": {        "no_permissions": "You do not have permissions to view this device!"    }
    This is my request,
    https://shelly-33-eu.shelly.cloud/device/status?id=XXX&auth_key=XXX
    I followed the instructions provided here.
    Thanks,
    Ruben
  • hey Ruben Cruz,
    Welcome here.
    Is your Device connected to the cloud?
    Do you have "RESTRICT LOGIN" enabled?
    Would you do your request local?
  • Hey Robert_M. ,
    It's connected to the cloud.
    RESTRICT LOGIN is disabled.
    I can do my request local.
    These are the current settings,
    Thanks,
    Ruben
    Einmal editiert, zuletzt von Gast10 (5. Januar 2022 um 05:43) aus folgendem Grund: full quote of last thread deleted.
  • did you fix this issue? I've got the same error and found out that I've used wrong device's id! Correct one is in device's info
    I have the same issue, I copied the DeviceId (the one in device info before and after the ( ). I still get the error
        "isok": false,
        "errors": {
    I just saw a similar thread: Apparently the device is not connected to my account!
    2 Mal editiert, zuletzt von hmrc78 (15. Februar 2022 um 11:55)
